Diff Drain Plug Removal
- Thank you received: 1881
19 Jan 2018 14:25 #188582
Replied by Lambert on topic Diff Drain Plug Removal
I agree entirely, it's a rare day that I really need a mechanic. I just have to emphasise the high stakes game that applying heat to a sealed container of flammable liquid is , that's all. Good luck with the job!
19 Jan 2018 19:27 #188590
by furo
Replied by furo on topic Diff Drain Plug Removal
I gave it a go and unfortunately didn't have any success. For both I used plenty of WD40. With the drain plug I decided to try the chisel technique without using the blowtorch, but it just bit into it and didn't rotate. I tried the blowtorch on one of the panhard nuts and used all my strength from different angles but there was no movement at all. I'm glad I gave it a good try though! I'll take it to the mechanic once we get through this snowy patch.
- Mraz
19 Jan 2018 20:08 #188593
by Mraz
Replied by Mraz on topic Diff Drain Plug Removal
I had the same problem with panhard bolts so I just cut them and put new ones in. Regular M10 if I remember.
19 Jan 2018 20:17 #188594
Replied by mlines on topic Re:Diff Drain Plug Removal
I know it's no consolation to you but the panhard rod bolts are prone to "Galling" or cold welding. The vibration fuses the threads of the nut and bolt together. With them being metric fine threads they become all but impossible to undo
Sent from my Nexus 6P using Tapatalk
19 Jan 2018 21:01 #188596
by furo
Mraz: unfortunately I don't have equipment for doing that but thanks for the suggestion
Mlines: it's good to hear that I'm not the only one! Glad I bought those bigjimny panhard bolts
20 Jan 2018 19:31 - 20 Jan 2018 19:31 #188626
by furo
Last edit: 20 Jan 2018 19:31 by furo.
Time to create page: 2.529 seconds
