Tow weight
16 Dec 2017 10:24 #187526 by Lambert
Replied by Lambert on topic Tow weight
Easily able to tow a braked trailer with a tonne in the back so long as the trailer is suitable. Most small ifor williams trailers have a mam of 1400kg and an unladen weight just below 300kg which is perfect for a Jimny. As has been said it does make a considerable impact on the performance of the car but being loaded should make you drive stedier regardless.
The following user(s) said Thank You: petejones69
16 Dec 2017 10:56 #187527 by Lambert
HUN wrote: I understand where the 1420kg come from (vehicle+people+luggage) but cannot see how 540kg is calculated unless it's just another recommended value. Bear in mind what I said is a factory (and my also) recommedation and what you said is a value based on the plate in the engine bay (mine is same). Personally I would not tow an unbraked trailer which weights 540kg whilst the car weights only 1100kg or less. Once I had to apply emergency brake on motorway with approx 300kg unbraked trailer...what can I say...was not fun at all.
But that's just my opinion anyway.
The construction and use regs as amended state that the unbraked tow limit is half the kerb weight of the car .
  • petejones69
16 Dec 2017 12:15 #187530 by petejones69
Replied by petejones69 on topic Tow weight
I'd only trundle along anyway if I had that load in tow. Can't wait to see how it handles some of the hills round where I live!
16 Dec 2017 12:35 #187531 by Lambert
Living on the edge of the Dales means I have all the serious hills I could want and then some and with my medium twin axle sheep trailer as long as I'm sensible it tows just fine.
16 Dec 2017 12:45 #187533 by facade
Replied by facade on topic Tow weight
11/60 wrote: Most small ifor williams trailers have a mam of 1400kg and an unladen weight just below 300kg which is perfect for a Jimny.
A 1400kg plated trailer is going to have you explaining to the policeman who stops you that the train weight is still below 2720kg because there is not a full load, most of them will take the max vehicle weight off the max train weight and get 1300kg, then spot the trailer is plated over that and you are into discussion time.
I remember a discussion a while back* (don't think it was on here) over this exact point and the legal status of an empty trailer plated to exceed the difference between the max train weight and max vehicle weight when full. No-one seemed to know, or could point to legislation that definitively said whether you could be prosecuted or not.
*was a while ago, but I think it was about using a borrowed heavy duty car transporter to collect a light car, so the loaded trailer would be way below the plated weight, but the plated weight exceeded the towing allowance.
16 Dec 2017 13:58 #187535 by Lambert
No that's old legislation. It has been superceded so that it is now actual weight not plated on trailers less than 3500kg.
Time to create page: 0.320 seconds
