Tow weight
- petejones69
15 Dec 2017 20:53 #187509
by petejones69
Tow weight was created by petejones69
How much weight could the Jimny tow? Thinking of getting a trailer.
Cheers
Pete
Cheers
Pete
16 Dec 2017 00:22 #187512
by Busta
Replied by Busta on topic Tow weight
1300kg braked, 540kg unbraked.
16 Dec 2017 06:56 - 16 Dec 2017 07:01 #187515
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic Tow weight
Hi Busta
According to my Owner's Manual your reply was a bit optimistic...
'weight' consists of three things (trailer+cargo+tow bar)
IF the trailer is braked then 'weight' = 450kg
IF the trailer is unbraked then 'weight' = 350kg
That's why I ended up buying only a very small trailer (i.e. Erde 102) which can be used legally (it weights 50-60kg hence useful capacity is only 290-300kg including tow bar)
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 16 Dec 2017 07:01 by HUN.
16 Dec 2017 07:51 - 16 Dec 2017 07:52 #187519
by facade
Replied by facade on topic Tow weight
Busta is right, the legal maximum is around 1300kg.
If you look at the VIN plate, the weights are on there, mine says
1420 is the maximum all up weight of the Jimny, 2720 is the maximum weight of the Jimny + trailer (so the max trailer weight is 1300kg)
680 is the maximum front axle loading 790 is the maximum rear axle loading. (allows for a degree of weight in the wrong place)
If they run it over a weighbridge, and any of the figures are exceed, then it is a construction & use offence.
The handbook recommends 450kg maximum braked, as with 1300kg on the back, performance is somewhat pedestrian. (And maybe the 450kg is off-road too)
The max nose weight is 75kg
Last edit: 16 Dec 2017 07:52 by facade.
- petejones69
16 Dec 2017 09:07 #187521
by petejones69
Replied by petejones69 on topic Tow weight
Great, so in theory I could haul a tonne, between the vehicle load and trailer load.
16 Dec 2017 10:15 - 16 Dec 2017 10:17 #187524
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
I understand where the 1420kg come from (vehicle+people+luggage) but cannot see how 540kg is calculated unless it's just another recommended value. Bear in mind what I said is a factory (and my also) recommedation and what you said is a value based on the plate in the engine bay (mine is same). Personally I would not tow an unbraked trailer which weights 540kg whilst the car weights only 1100kg or less. Once I had to apply emergency brake on motorway with approx 300kg unbraked trailer...what can I say...was not fun at all.
But that's just my opinion anyway.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 16 Dec 2017 10:17 by HUN.
Time to create page: 0.370 seconds
