Gear stick play?
07 Nov 2017 17:51 #185965
Replied by Riccy on topic Gear stick play?
Your right, that link refers to the earlier R7ME gearbox,
You should have a white plastic bushing on the end of the stick shaft. it clips onto the ball end to square it off. Would be really sloppy without it.
Martin (the forum main man) can get suzuki genuine parts so should be able to source one for you
Cant help with a part number tho
07 Nov 2017 17:54 #185966
P.S. if you make a bush i would use a rigid plastic rather than bronze (which will transmit noise something rotten!)
07 Nov 2017 17:56 #185967
PP.S...
The picture of your gearbox connection looks wrong. The collar is damaged and is inside the body when it should be below? why is it sitting so high?
- Mraz
07 Nov 2017 18:08 - 07 Nov 2017 18:38 #185969
by Mraz
Replied by Mraz on topic Gear stick play?
I assume it was damaged when it was removed and I honestly have no idea why it protrudes inside the body. I got the car year ago and drive it like it is. No leaks, no grinding noise, all gears work fine and are easy to engage (second is a bit harder), 4H/4L works fine.
EDIT: Just took a look under the car and nothing seem out of place or bent.
Last edit: 07 Nov 2017 18:38 by Mraz.
07 Nov 2017 18:53 #185976
my bad, i have a 2" body lift, so mine is lower!
- Mraz
07 Nov 2017 19:03 #185977
by Mraz
You almost gave me a heart attack!
Time to create page: 1.203 seconds
