Gear stick play?
  • Mraz
07 Nov 2017 23:03 #185984 by Mraz
Replied by Mraz on topic Gear stick play?
I found the diagram but I'm not sure wht part do I need?
24, 25, 19, 30?
  • Andy
18 Sep 2019 18:13 #213679 by Andy
Replied by Andy on topic Gear stick play?
Hi, my 2008 model is just like yours and I am having trouble finding the correct bush. How did you finally fix the problem.
Andy
18 Sep 2019 21:24 #213689 by Fossie
Replied by Fossie on topic Gear stick play?
There is a white nylon bush that fits at the bottom of the gear-lever ball.
Remove the 3 screws around the ring under the rubber boot.
This will give access to the lever and it will pull out . The area is full of grease and once the bush wears it can slip to one side, limiting movement of the lever.
It is really a 15 minute job , but just a get a new bush to fit they aren't much.
  • Andy
19 Sep 2019 06:27 #213694 by Andy
Do you know the part no. Had 2 different ones from suzuki but do not fit as are too big.
19 Sep 2019 22:10 #213729 by Fossie
NEW-Suzuki-JIMNY-Gear-Lever-Stick-Shift-End-Bush-25551-60A02/
£14.00
  • Andy
20 Sep 2019 12:27 #213747 by Andy
Tried that one to wide to fit
