Vaccuum pipes and manual hubs
- Roo
17 Sep 2017 14:20 #184196
by Roo
Vaccuum pipes and manual hubs was created by Roo
When fitting manual hubs what do you do with the vacuum pipes to stop the green 4wd indicator flashing and allow you to engage 4wd low range?
Thanks in advance.
Thanks in advance.
- Mraz
18 Sep 2017 04:21 #184212
by Mraz
Replied by Mraz on topic Vaccuum pipes and manual hubs
What year is your Jimny?
- Thank you received: 115
18 Sep 2017 15:25 - 18 Sep 2017 15:30 #184218
by maverick
Locate the brass pipes from the hub assembly and fit a piece of pipe between them, and block-off the the pipe assembly and tuck away ... some poeple take them all off ...
Jalapeño, IISY?
Replied by maverick on topic Vaccuum pipes and manual hubs
Jalapeño, IISY?
Last edit: 18 Sep 2017 15:30 by maverick.
19 Sep 2017 13:46 #184254
by Bosanek
Replied by Bosanek on topic Vaccuum pipes and manual hubs
See if this article is of some help:
www.bigjimny.com/mediawiki/index.php?tit...ront_wheel_hub_heads
Time to create page: 2.331 seconds
