Rear Washer leak
  • Big Al
02 Jul 2017 08:36 #182424 by Big Al
Rear Washer leak was created by Big Al
Why does my rear washer jet leak on my Jimny
  • ZukracerV6
02 Jul 2017 11:12 #182431 by ZukracerV6
Replied by ZukracerV6 on topic Rear Washer leak
Where is it leaking from? Could be a faulty non return valve, split pipe, leaking joint or a blocked jet and/or non return valve causing back pressure and then a failure in a joint etc.
Does it leak when your using the front washer?
  • Big Al
02 Jul 2017 11:57 #182432 by Big Al
Replied by Big Al on topic Rear Washer leak
Does not leak when using front wiper.
02 Jul 2017 17:11 #182433 by mlines
Replied by mlines on topic Rear Washer leak
usually a failed non-return valve
  • Cameronmike
02 Jul 2017 17:12 #182434 by Cameronmike
Replied by Cameronmike on topic Rear Washer leak
If its just kinda leaking out when the car's parked facing up a slope etc that's what was happening to mine and was just the wee black inline non return valve that had went. Pretty generic part that you can get off eBay no bother. Located behind the plastic trim on the boot door which just pops off, although it comes off easier if you open the boot then lock it so you can wiggle it past the wee locking button thing. Best of luck.
Time to create page: 0.147 seconds
