Jimny brake drum removal bolts
  • Fidler33
08 May 2017 09:19 #181038 by Fidler33
Jimny brake drum removal bolts was created by Fidler33
I read here that the bolts that fit the Jimny brake drums to push them off are m8, but m8 seems to be too big for mine.
None of the bolts I have in my box of odds would fit.Does anyone know what size/tpi bolts I need?
08 May 2017 10:16 #181043 by mlines
08 May 2017 10:19 #181045 by X8GGY
PM me your address and I'll post you a couple ;)
08 May 2017 10:40 #181046 by yakuza
On old Suzuki SJ there is no holes for tearsing so if using bolts fails this may help.
I often get the drum off by one of two methods:
1. Use a wheel or preferably just he rim. Hang the rim on the stud bolts and screw on bolts only halfway on. use the slack to yank the rim in-out as a sliding hammer. others i heard also wack the rim with a large club or hammer. Take care not to damage the threads.
2. Use a rim or brake disc and hang it on the stud bolts with nuts on half way in. use a pry bar between the rim/disc and the center of the hub to press/pull the drum out.
Hoping this was explanatory and not lost in translation. (i am norwegian :) )
  • Fidler33
08 May 2017 10:41 #181047 by Fidler33
Replied by Fidler33 on topic Jimny brake drum removal bolts
I bought some m8's but the diameter is too large - perhaps they are m7
  • Fidler33
08 May 2017 10:44 #181048 by Fidler33
Thanks but I think mine are non standard - m8 too big in diameter
Time to create page: 0.443 seconds
