springs are shorter than shocks' max length
  • Jimny987
17 Apr 2017 02:17 - 18 Apr 2017 02:05 #180312 by Jimny987
Hi,
Last week I lifted up my jimny for maintenance, tyre hung down naturally and the shock extended to it's max.
In this situation, I observed that the springs are shorter than shock and it can be moved easily.
Is it normal? or my springs are too short?
Last edit: 18 Apr 2017 02:05 by Jimny987.
18 Apr 2017 06:56 #180357 by Busta
Your springs are too short or your shocks are too long. Are you using shock extender brackets by any chance?
The following user(s) said Thank You: Jimny987
  • Jimny987
18 Apr 2017 08:11 #180360 by Jimny987
Replied by Jimny987 on topic springs are shorter than shocks' max length
Thanks for reply,
I am not using extender brackets.
How about adding a spring spacer to fix it?
18 Apr 2017 09:43 #180361 by mlines
Sounds fairly normal to me. As the springs and shocks are not combined (ie. MacPherson strut) but sit separately they tend to work almost independently.
  • Jimny987
18 Apr 2017 10:12 #180363 by Jimny987
If it's normal, can I add spring spacer to get it tight?
Will adding a spring spacer effect the suspension system in the situation?
