Throttle bodies
12 Apr 2017 19:53 #180195 by Keithy
Replied by Keithy on topic Throttle bodies
I used the Jimny ICV as the liana one had different pipework and was seized.
Yakuza, there are four manifold runners and one inlet...hth
My manifold inlet was 46mm Riccy...I enlarged it to 50....got some higher revs afterwards.
12 Apr 2017 20:06 #180196 by yakuza
Replied by yakuza on topic Throttle bodies
Keithy: The manifold on the 08 Liana was 50mm on the TB-side, but throttle body on the intake side was was 46mm.
bigger towards air filter side.
Hope to have explained it better now?
Can post pics if you like.
We are actually discussing very small differences on engine details of Top Gears "reasonably priced car"..
It's not like any of us will notice how the sorroundings go blurry when we we press the accelerator and go into warp speed :)
But i Love it!
12 Apr 2017 20:59 #180199 by Keithy
yakuza wrote: Keithy: The manifold on the 08 Liana was 50mm on the TB-side, but throttle body on the intake side was was 46mm.
But i Love it!
So you have a 46mm throttle body mated to a 50mm inlet?
Might get a set of 38mm throttle bodies and rid mine of the nasty inlet manifold altogether.
The scenery had better go blurry after shelling out for 9.0:1 pistons and 500hp conrods to withstand the turbo.....
18 Apr 2017 11:51 #180371 by Rhinoman
Replied by Rhinoman on topic Throttle bodies
I ran a test in the Ignis (1.5) and had no trouble hitting the baro reading so no restriction there and the air filter (OEM) hasn't been changed for at least 20k.
18 Apr 2017 11:54 #180372 by Rhinoman
yakuza wrote: We are actually discussing very small differences on engine details of Top Gears "reasonably priced car"..
The Swift Sport engine has around 30% more power than the "reasonably priced car" and around 50% more power than a Jimny so it would be no real surprise if the Jimny's intake and exhaust system were holding back a significant amount of power.
19 Apr 2017 04:13 #180391 by Lambert
Replied by Lambert on topic Throttle bodies
Rhinoman wrote: I ran a test in the Ignis (1.5) and had no trouble hitting the baro reading so no restriction there and the air filter (OEM) hasn't been changed for at least 20k.
So that is with the 46mm on a 1.5? Is the rest of the intake the same after the throttle body on the 1.5, the manifold?
Time to create page: 1.204 seconds
