Throttle bodies
12 Apr 2017 05:39 #180163 by Lambert
Throttle bodies was created by Lambert
After reading all the recent threads on people swapping the m13 to m16 and the evident need to get a 50mm throttle body this raises a fairly obvious question, is there any benefit from putting a 50 on a m13, assuming that the vvt isn't 50mm already? More bigger, more better, right?
12 Apr 2017 11:05 #180174 by Keithy
Replied by Keithy on topic Throttle bodies
Just needs to be big enough really....have you measured the 1.3vvt yet?
12 Apr 2017 11:17 #180175 by Lambert
Replied by Lambert on topic Throttle bodies
Not yet. But it is on the list.
12 Apr 2017 12:19 #180176 by Rhinoman
Replied by Rhinoman on topic Throttle bodies
11/60 wrote: After reading all the recent threads on people swapping the m13 to m16 and the evident need to get a 50mm throttle body this raises a fairly obvious question, is there any benefit from putting a 50 on a m13, assuming that the vvt isn't 50mm already? More bigger, more better, right?
I doubt if there would be any significant improvement, 45mm should flow enough air for a stock 1.3 although its a little small for a 1.6. The simplest test is to run flat out and measure the manifold pressure, if its lower than the baro reading then there is a restriction. peak airflow is at peak torque so you need to fully load the engine at around 3500rpm. Then you would need to determine if the restriction is in the air intake, the throttle body, the manifold or the head.
My Jimny is relegated to field duties so I can't test that, I might try it in the Ignis though.
12 Apr 2017 18:56 #180191 by Riccy
Replied by Riccy on topic Throttle bodies
Keithy wrote: Just needs to be big enough really....have you measured the 1.3vvt yet?
1.3VVT = 46mm
1.6 2004 liana = 50mm.
Jimny manifold will take either, inlet hole on it is the same size on both (which is why i thought they were the same).
Is there any difference in the idle control part of it? mines not idling the same after swapping the throttle body, and had a splutter session the other day as well.
Riccy
12 Apr 2017 19:40 - 12 Apr 2017 19:42 #180194 by yakuza
Replied by yakuza on topic Throttle bodies
my 08 Liana M16A vvt (plastic intake manifold) had 46mm throttle body.
But have i measured the wrong end of it? this is on the engine side, the smallest diameter.
On the aussie forum someone said to use the Jimny idle thing (valve?).
Last edit: 12 Apr 2017 19:42 by yakuza.
Time to create page: 1.379 seconds
