Tie Rod Ends - Nearside.
  • slippy
26 Jul 2016 11:03 #170543 by slippy
Tie Rod Ends - Nearside. was created by slippy
Just checking before I order parts. Have two tie rod ends on the nearside ( UK vehicle - RHD) and only one tie rod end on the offside. So the part no for the two nearside tie rod ends is 48810-81A00 is that correct?
26 Jul 2016 14:37 #170552 by jackonlyjack
not sure on part numbers
but i would advise you to unbolt the one you're going to replace
just to make sure the steering rod as not been fitted 180 degrees out
ie the wrong way round because if you buy right hand thread you may need left hand thread
Jack
26 Jul 2016 14:50 #170556 by mlines
Replied by mlines on topic Tie Rod Ends - Nearside.
I agree on the advice, whilst the rod ends are handed, it is possible to fit it the wrong way around so you end up buying the wrong ends.
The BigJimny store identifies the rod end and the part numbers you need
  • slippy
26 Jul 2016 16:00 #170562 by slippy
Replied by slippy on topic Tie Rod Ends - Nearside.
Have just unbolted the two nearside ends. Both undo turning anti-clockwise so they are right handed threads then.
26 Jul 2016 16:04 #170563 by jackonlyjack
slippy wrote: Have just unbolted the two nearside ends. Both undo turning anti-clockwise so they are right handed threads then.
correct ;)
26 Jul 2016 19:08 #170577 by Johnniehec
Replied by Johnniehec on topic Tie Rod Ends - Nearside.
Just buy two of each and replace them all, they're not expensive from the Bigjimny shop, simples!
Time to create page: 0.337 seconds
