Gear stick bush needed
11 Jun 2016 15:21 #168356
by gilburton
Replied by gilburton on topic Gear stick bush needed
When you say you couldn't get it to fit do you mean the nylon bush wouldn't fit in to the eye of the remote or you couldn't get the bayonet fitting to locate??
I didn't have any trouble fitting mine and it only took a few minutes to replace once the centre console was removed??
- Barkis21
15 Jun 2016 19:15 #168627
by Barkis21
Replied by Barkis21 on topic Gear stick bush needed
Can't get the nylon bush in the hole it 2006 vvt is it the same as earlier ones don't know if there's any difference.
- Thank you received: 680
15 Jun 2016 19:26 #168629
Replied by jackonlyjack on topic Gear stick bush needed
try putting the bush in the freezer over night
in a bag with a smear of petroleum jelly on it
Jack
Jack
15 Jun 2016 19:57 - 15 Jun 2016 20:16 #168632
by gilburton
It shouldn't be tight. It should just drop in to the eye it's not a press fit and as you have a used one it should be slightly worn.
Do you have the eye straightened up?
Use a rod or something to straighten it up and in neutral.
It should look like this diagram? If not do you have the correct part?
Check out the "bayonet" fitting on the gear lever and the arched alloy remote supports as they were only fitted to the VVT box.
The earlier boxes had steel supports.
There is just a chance you either have the wrong part or someone has fitted an earlier box??
Does the replacement match your original one??
www.bigjimny.com/media/kunena/attachments/63/SideBySide.pdf
Last edit: 15 Jun 2016 20:16 by gilburton.
- Barkis21
18 Jun 2016 15:13 #168790
by Barkis21
Thanks guys all sorted now
Time to create page: 0.156 seconds
