sun strip and MOT
07 Apr 2016 13:57 #164993 by Halford
sun strip and MOT was created by Halford
can any MOT expert advise if I'll need to remove my tinted sun visor strip prior to submitting the car for its MOT ?
have had mixed messages
1.) if it encroaches into the wiper zone = fail (it does)
2.) sunstrips cant come lower than the internal sun visor when it's down (it doesn't)
easy enough to rip it off and fit another after the MOT as they're only £10, but would rather not it not necessary.
thanks MOT testers
07 Apr 2016 20:16 #165015 by jackonlyjack
Replied by jackonlyjack on topic sun strip and MOT
i have had 2 passes and 2 fails :unsure:
was solid black 250 mm deep for all 4 mot's
it will depend on the tester ;)
Jack
The following user(s) said Thank You: Halford
  • helijohn
07 Apr 2016 21:39 #165019 by helijohn
Replied by helijohn on topic sun strip and MOT
Never a mention on both my motors and the one has had a sunstrip for over a decade.
  • Daniel30
07 Apr 2016 23:17 #165023 by Daniel30
Replied by Daniel30 on topic sun strip and MOT
Halford wrote: can any MOT expert advise if I'll need to remove my tinted sun visor strip prior to submitting the car for its MOT ?
thanks MOT testers
I would just ask them when I got there if they said it would not pass just take it off there and then ;)
08 Apr 2016 03:18 #165024 by Halford
Replied by Halford on topic sun strip and MOT
jackonlyjack wrote: i have had 2 passes and 2 fails :unsure:
Jack
Guess the trick is to find a short MOT tester who sits low down on the seat :whistle:
08 Apr 2016 05:04 #165025 by Lambert
Replied by Lambert on topic sun strip and MOT
When you say tinted how dark is it and does it fade from top to bottom? I have had cars with sun strip fades in the actual screen and one was failed as intruding on the sweep of the wipers so I just got a couple of shorter blades for the duration of the retest and then the next year used a different test center.
Time to create page: 0.330 seconds
