water leak
- jewi
27 Dec 2015 15:53 #159204
by jewi
water leak was created by jewi
My washer bottle keeps loosing its water!
I have checked and the seals where the pumps go look ok with no sign of water, there appears to be no splits in the pipe work and i have traced the rear pipe work and that looks ok.
The only thing i can see is there is a drop of water coming out of the washer jet on the drivers side but surely it can't be that?
I have replaced the washer bottle as the previous one done the same.
Any suggestions would be appreciated.
Paul
Paul
27 Dec 2015 16:34 - 27 Dec 2015 16:49 #159207
by kirkynut
Replied by kirkynut on topic water leak
Water comes out of the washer jets if you are parked at a funny angle and the level is high enough as the washer fluid can be level with or higher than the jets with the reservoir being mounted so high.
Do you loose enough to empty it though?
I notice some coming out of the jets when driving and I've not squirted the screen.
I fancy there might be a bit of capillary action going on too.
Last edit: 27 Dec 2015 16:49 by kirkynut.
- jewi
27 Dec 2015 16:47 #159208
by jewi
Replied by jewi on topic water leak
it takes 2/3 days for it to empty fully, i might try and only half fill it and see if that makes a difference
27 Dec 2015 16:50 #159211
Replied by mlines on topic Re:water leak
Anti return/siphon valves stuck?
Sent from my Nexus 5 using Tapatalk
- jewi
27 Dec 2015 16:54 #159212
by jewi
I dont know what they are
Replied by jewi on topic Re:water leak
mlines wrote: Anti return/siphon valves stuck?
- jewi
27 Dec 2015 17:08 #159213
by jewi
i have just had another look, from the pump it goes to a straight joint piece (no valve in and clear of any obstructions), the pipe then goes to a 'Y' piece then to each jet. There is no one way valve, should it have one?
Time to create page: 0.188 seconds
