Aerial Alternative?
  • Grego
22 Nov 2015 14:43 #156883 by Grego
Aerial Alternative? was created by Grego
I snapped my aerial reversing in the woods (twice) and know I will do it again, but as the Jim aerial is not cheap to replace has anyone fitted a flexie alternative to the existing mounting?
22 Nov 2015 14:57 #156885 by Rhinoman
Replied by Rhinoman on topic Aerial Alternative?
You can get a box that lets you use a CB antenna.
The following user(s) said Thank You: Grego
  • helijohn
22 Nov 2015 19:32 #156943 by helijohn
Replied by helijohn on topic Aerial Alternative?
Not the existing mount but in the middle rear of the roof. ;)
  • gusthegorilla
22 Nov 2015 19:37 #156944 by gusthegorilla
Replied by gusthegorilla on topic Aerial Alternative?
Rhinoman wrote: You can get a box that lets you use a CB antenna.
It's one of these, used in conjunction with std cb antenna
  • Grego
22 Nov 2015 20:50 #156963 by Grego
Replied by Grego on topic Aerial Alternative?
Thanks all, Well explained, will look into it and probably fix it to the original mount where the aerial has snapped off and tie it to the roofbar so I'm ok reversing :)
22 Nov 2015 23:43 - 22 Nov 2015 23:44 #156985 by kirkynut
Replied by kirkynut on topic Aerial Alternative?
You can get an aftermarket replacement Jimny aerial on ebay for about a tenner I think. Straight forward replacement.
I have the box to use the cb aerial above though and it does give better reception.
Last edit: 22 Nov 2015 23:44 by kirkynut.
Time to create page: 0.898 seconds
