Phonic wheel (speedometer sensor gear) Jimny VVT
- jimnynatal
28 Oct 2015 18:44 - 28 Oct 2015 19:33 #154728
by jimnynatal
Phonic wheel (speedometer sensor gear) Jimny VVT was created by jimnynatal
Hello!
Does anyone know manufacturer, model or part number of the phonic wheel (speedometer sensor gear, or counter gear) for the Jimny VVT? Or simply have photos?
I am buying a programable injection controller, and the manufacturer asked me about the phonic wheel.
Thank you very much
Sandro
Thank you very much
Sandro
Last edit: 28 Oct 2015 19:33 by jimnynatal.
28 Oct 2015 20:00 #154737
by Rhinoman
Replied by Rhinoman on topic Phonic wheel (speedometer sensor gear) Jimny VVT
- jimnynatal
13 Nov 2015 13:15 #156180
by jimnynatal
Replied by jimnynatal on topic Phonic wheel (speedometer sensor gear) Jimny VVT
Thank you, Rhinoman!
You helped me a lot with those pictures! Great!
Well, I have also learned that:
There are three phonic wheels, all of them with 3 wires hall sensors close to them.
1. VSS - Vehicle Speed Sensor - a speed sensor, located in the end of the transfer case. Here, the phonic wheel is a simple speedo ring, a counter gear, with same spacing teeth. There are 25 teeth in it.
2. CKP - CranKshaft Position sensor - there is a coded teeth wheel attached in the flywheel, and it has the same speed of the engine. I dont know how many teeth, and the no teeth intervals.
3. CMP - CaMshaft Position sensor - there is a coded teeth wheel connected to the chain of the camshaft. I dont know how many teeth, and the no teeth intervals.
If anyone has photos, drafts or any information about these gears, please, tell us.
Thank you very much!
- BigT
13 Nov 2015 17:43 #156199
by BigT
Replied by BigT on topic Phonic wheel (speedometer sensor gear) Jimny VVT
The CKP SCOPE trace that Rhinoman sent you, the pulses that are close together are at 10 degree intervals and the larger parts
where their are no pulse are 30 degree intervals.
If this confuses you I could post a clearer scope trace for you taken from my car.
- jimnynatal
13 Nov 2015 18:28 #156202
by jimnynatal
If you can, please, send it. I'll help. Thank you.
- BigT
13 Nov 2015 19:58 - 13 Nov 2015 19:59 #156210
by BigT
Last edit: 13 Nov 2015 19:59 by BigT.
Time to create page: 0.797 seconds
