Trailmaster 2 inch
  • highball
08 Oct 2015 20:01 #153243 by highball
Trailmaster 2 inch was created by highball
hi guys I'm real close to buying 2 inch trail master lifting kit but before I commit I need to know if there's anything else I need to buy ? I've heard about a correction kit ? And new break lines ? Anyway be glad of any advise.
08 Oct 2015 20:13 #153246 by mlines
Replied by mlines on topic Re:Trailmaster 2 inch
The kit I sell includes everything including the longer brake line.
We did not put caster correction on our Jimny as a two inch lift does not affect it too much. There is a slight change but not a lot and its preferable to the harsher ride that a typical correction bush would bring
Sent from my Nexus 5 using Tapatalk
The following user(s) said Thank You: highball
  • highball
08 Oct 2015 21:10 - 09 Oct 2015 00:51 #153253 by highball
Replied by highball on topic Re:Trailmaster 2 inch
Sorry to be asking so many questions but I want to make sure I get it right. Should I buy a three inch lift or two ? I use the jimny everyday to go to work but it's only 3 miles each way but intend to do some off roading. Thanks again.
Last edit: 09 Oct 2015 00:51 by highball.
  • highball
09 Oct 2015 10:23 #153289 by highball
Haha ignore my last post , the description in your shop answered it
  • TomDK
09 Oct 2015 12:02 - 09 Oct 2015 16:22 #153290 by TomDK
Replied by TomDK on topic Re:Trailmaster 2 inch
highball wrote: Sorry to be asking so many questions but I want to make sure I get it right. Should I buy a three inch lift or two ? I use the jimny everyday to go to work but it's only 3 miles each way but intend to do some off roading. Thanks again.
I can help you with that.
The Trail Master Standard 2" lift springs and the 3" springs are actually the same height. The difference is that the 3" springs are much harder. The 2" diesel diesel springs are 15mm shorter.
Hope this helps.
Spring rates and free length, front springs.
Standard Jimny springs: 21 N/mm
Trail Master 2" springs: 26 N/mm - 368 mm
Trail Master 2" diesel springs: 36 N/mm - 353 mmm
Trail master 3" (diesel) springs: 40 N/mm - 368 mm
I don't have specs on the rear springs. But the 2" springs are the same for diesel and petrol. 3" lift springs are longer. If you decide to go for 3" lift consider 2" lift springs for the rear. The 3" rear springs are rather long compared to the front ones. So only use these if you drive with a heavy load in the back.
Last edit: 09 Oct 2015 16:22 by TomDK.
  • highball
09 Oct 2015 19:46 #153306 by highball
thankyou dk, 2 inch it is, but the wife says i have t5o wait for january with xmas on the way, gutted
Time to create page: 4.207 seconds
