Winches
  • highball
10 Oct 2015 19:15 #153369 by highball
Replied by highball on topic Winches
Thanks basketcase and Tomdk I will not nay do ocassional green lanes so will take my chances with a cheap one
11 Oct 2015 05:27 #153386 by Lambert
Replied by Lambert on topic Winches
The other thing is that if you are not using the winch that often that can actually do it no good as much as it being cheap in the first place. What I mean is that because a cheap winch is built to a budget not only does that increase the liklihood of component failure under working conditions but it also means that things like seals on gearing and solenoid packs etc will not be good at keeping road spray and rain out meaning that it is more likely to fail just from lack of use. Also worthy of consideration is the availability of spare parts as often the parts needed to fix a cheap item are individually more expensive than the original purchase of a complete one. What I'm getting at is just be careful, cheap is not the same as good value.
The following user(s) said Thank You: highball
  • mkay
19 Oct 2015 16:29 - 19 Oct 2015 16:33 #153916 by mkay
Replied by mkay on topic Winches
I have a £90 3000lb ATV winch which even without a snatch will pull me out of ruts but for a ditch I would use the snatch. I am sure for most people green laning this is the extent of their needs, just don't rescue discos.
Only problem is the drum size but I never need to winch right upto the anchor so I just carry a spare length of rope.
Last edit: 19 Oct 2015 16:33 by mkay.
  • Daniel30
19 Oct 2015 17:15 #153922 by Daniel30
Replied by Daniel30 on topic Winches
Thanks for the info that is probably what I would need a winch for cheers
Time to create page: 0.289 seconds
