No reverse
  • Brownie
14 Sep 2015 11:53 #151963 by Brownie
No reverse was created by Brownie
So last night I heard a big clunk and then I couldn't reverse. The reverse light comes on but it just doesn't reverse I know my clutch release bearing was noisy could it have just failed it engages all the forward gears just not reverse
  • fozzie
14 Sep 2015 15:31 #151971 by fozzie
Replied by fozzie on topic No reverse
Ouch!
Unfortunately it sounds like you have a gearbox problem. I'm sure that the clutch release bearing isn't the culprit. It might be noisy, but it wouldn't stop you just selecting reverse.
14 Sep 2015 16:04 #151973 by mlines
Replied by mlines on topic Re:No reverse
Will it go into 5th? If not then broken mount?
Sent from my Nexus 5 using Tapatalk
  • Brownie
14 Sep 2015 17:49 #151985 by Brownie
Replied by Brownie on topic Re:No reverse
Ye it goes into 5th and will alot into reverse but it doesn't do anything
14 Sep 2015 18:40 #151995 by Busta
Replied by Busta on topic No reverse
Definitely a gearbox problem. For the reverse lights to work, the switch inside the gearbox is obviously being pressed but something else in there isn't doing what it should!
Time to create page: 0.209 seconds
