Fuel tank
07 Sep 2015 11:09 #151473
Fuel tank was created by Daniel30
Does anyone else's tank make a whooshing noise when they undo the filler cap at the petrol station, I've just been reading a thread on an engine failing to start and this was one of the suggestions if the fuel tank was vented properly?? Mine is really loud and I was wondering if it was a problem that was starting to accur if this makes sense?
Cheers
Cheers
- wombat
07 Sep 2015 11:16 #151474
by wombat
Replied by wombat on topic Fuel tank
Hi, mine does it, especially if the tank is nearly empty. My last jimny did it as well but have never had any problems
cheers
Ian
cheers
Ian
07 Sep 2015 11:39 #151475
Replied by Daniel30 on topic Fuel tank
Cheers wombat (Ian)
07 Sep 2015 11:57 #151477
by facade
As above, it is supposed to, the tank is sealed to prevent any fumes escaping except into the carbon cannister by the alternator.
Air can get in, but vapour can't get out, so when the fuel is warm, you will get a hiss of vapour escaping.
If it never hisses, then likely the tank is leaking, usually around the filler spout where mud gets between the rubber hose and steel spout. (Make sure you keep this area clean)
07 Sep 2015 12:00 #151478
Thanks it must be ok then
- Decklandpt
07 Sep 2015 23:36 #151519
by Decklandpt
Replied by Decklandpt on topic Fuel tank
yeah, every car i ever had did that. the emptier the tank, the bigger the hiss
