Front axle parts
- Chris d
12 Aug 2015 13:32 #149685
by Chris d
Front axle parts was created by Chris d
:S hi guys I took me Jim in garage today he say not good I need front hub seal kit front wheel bearings and possible king pin bearings and seals there's no way I can afford 235 quid a side for genuine bits that's just the hub seals so he says any advise welcomed thanks
- mickt
12 Aug 2015 18:49 #149696
by mickt
Replied by mickt on topic Front axle parts
Plenty of threads on this subject detailing what you need and how to do it. Just search the topics/
- Chris d
12 Aug 2015 19:14 #149700
by Chris d
Replied by Chris d on topic Front axle parts
Thanks pal will take a look and see what I can see I just thought the likes of Jimny bits etc may of sold the bits I'm after cause my local a2 motor parts said they where main dealer only any info is a help thanks again
12 Aug 2015 19:54 #149702
Replied by mlines on topic Re:Front axle parts
There is always the BigJimny shop ON THIS WEBSITE
Sent from my Nexus 5 using Tapatalk
13 Aug 2015 09:40 #149727
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Front axle parts
+1 for the Big Jimny shop. All the parts you need are normally there, And if not Martin will let you know when they will be if you ask.
13 Aug 2015 16:10 #149757
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front axle parts
Big jimny shop will sort you and its probably kingpin bearings and the inner seal only you need. Get your mechanic to waggle the wheel with your foot on the brake if you only have top to bottom play then you shouldn't need wheel bearings. The big seal on the back is more of a dust seal. If it's leaking oil it will be the inner seal due to worn kingpins. £30 ish per side including inner seal then fitting
Grey pick up Jimny
Time to create page: 3.069 seconds
