Jimny not well!
- Solas
Daniel30 wrote: Manual hubs you have to get out of the jimny and lock them the push button ones use the vacuum to lock the hubs (front wheels)from inside the jimny, I'm not a mechanic but I don't think it will be much to get your vacuum pipes sorted
It's push buttons I have, how do you lock 4wd from outside?
- Thank you received: 1869
See Kirkynuts thread about locking the vacuum hubs but it involved taking the hub off and moving the locking collar inside. Once set to locked they should stay locked.
Replacing the vacuum pipes is a simple job and should see it all back to normal in an hour or 2.
Once fixed you can also add a simple 2low switch if the idea of using low range in 2wd appeals to you. As 11/60 says, its a very useful mod!
- Solas
