Idle up switch or hand throttle ?
  • GraphicX
10 Jun 2015 11:28 #145745 by GraphicX
Idle up switch or hand throttle ? was created by GraphicX
hey guys
i'd like to be able to increase my jimny's idle speed when placing load on the battery.
i can think of a couple of ways to do it, one would be a hand throttle using a cable to the throttle body, but another 'might' be to somehow change the idle with a simple switch the same way the ECU ups the idle speed when it warms up.
does any one know if it's possible to use a switch to increase idle speed ? if so, where would i be needing to wire up to etc ? thanks.
10 Jun 2015 16:45 - 10 Jun 2015 16:46 #145774 by facade
There is an ecu input for the aircon clutch engaged which should give a faster idle.
From my diagrams it might be ECU pin 16 green&white, looks like you earth it out to get something to happen, or it might just fry the ECU :ohmy: , I could do with an ECU pinout diagram, rather than the strange Suzuki wiring diagram to be sure.
TBH, a choke cable with a bit of fettling around the throttle valve would be safer.
Last edit: 10 Jun 2015 16:46 by facade.
The following user(s) said Thank You: GraphicX
  • helijohn
10 Jun 2015 20:31 #145782 by helijohn
Replied by helijohn on topic Idle up switch or hand throttle ?
GraphicX wrote: hey guys
i can think of a couple of ways to do it, one would be a hand throttle using a cable to the throttle body,.
I have that as standard on my Pajero and I fitted something similar to my Pinin using a choke cable and a coupling on the end of the throttle cable where it meets the pedal arm.
  • GraphicX
11 Jun 2015 00:14 #145788 by GraphicX
Replied by GraphicX on topic Idle up switch or hand throttle ?
No eBay APP ID and/or Cert ID defined in Kunena configurationthanks guys, i've had my eye on this hand throttle for a little while:
i just wasn't sure about how to go about attaching it. i did look at the throttle body in the hope of there being a place to attach it there, but i can only see crimping it to the throttle cable which i wasn't keen on.
so do you think my best bet would be to somehow attach it to my accelerator pedal john ?
  • helijohn
11 Jun 2015 05:41 #145791 by helijohn
It's sort of up to you but I made up a link which slotted around the end of the throttle cable at the top of the Pinin's pedal.
I bought a choke cable off eBay (eBay item number:391035065658) and tailored the coupling to suit the choke cable end fitting. I had to shorten the cable and so I went for one with a solid inner wire rather than stranded.
11 Jun 2015 12:17 #145815 by Rhinoman
facade wrote: There is an ecu input for the aircon clutch engaged which should give a faster idle.
Which ECU is it?
Time to create page: 0.277 seconds
