Failed MOT- body mount rust and suspension bush. Any thoughts?
08 May 2015 13:16 #143888 by minibbb
Afternoon gents
Sadly my brothers 2001 jimny failed it's mot today on the body mount being corroded and the rear offside suspension bush worn.
This is the body mount....
Sills also have some surface rust which was an advisory along with brake/fuel lines
Has anyone managed to repair the mounts properly?
Also where is the best place to get a suspension bush? Worth doing them all on that arm?
08 May 2015 13:33 #143890 by minibbb
Does this look ok? Suzuki want £28 a bush. Not sure if they're both the same?
10 May 2015 15:59 #143993 by minibbb
Anyone able to help re the rear bushes, I.e whether they're both the same and the one above is the right one?
10 May 2015 16:24 #143994 by mlines
The two at the axle end are different to the one at the chassis end.. After market ones tend to be solid whilst Suzuki ones have slots in them
Sent from my Nexus 5 using Tapatalk
10 May 2015 17:31 #143999 by minibbb
mlines wrote: The two at the axle end are different to the one at the chassis end.. After market ones tend to be solid whilst Suzuki ones have slots in them
Thanks Martin- this is the one that's gone. Is the one above the correct bush?
10 May 2015 21:16 #144012 by facade
If you pay £28 for a Suzuki bush it will fit.
ECP rarely supply the correct part (but they do have a good returns policy :) )
The following user(s) said Thank You: minibbb
Time to create page: 0.831 seconds
