Constant white smoke
  • Sasquatch
24 Mar 2015 23:08 #141298 by Sasquatch
Constant white smoke was created by Sasquatch
Hi,
I have just purchased my first 4x4 a 1999 Suzuki Jimny 16v. I has not been used for the last year. It starts and runs very well but has constant white smoke from the exhaust. The guy I brought it from said that it was a struggle to get it through the emissions test on the last MOT.
I have changed the oil and filter and stuck a can of Redex stop smoke in but its still smoking. There is no white in the oil and the water level is not going down.
Can anyone give advice on what might be causing this, Valve stem seals, worn rings ??
Cheers Colin
  • suzukisam
25 Mar 2015 06:51 #141300 by suzukisam
Replied by suzukisam on topic Constant white smoke
Headgasket but to be honest i bought one that was stood for 2 years and i put the engine and exhaust onto mine and it white smoked for ages but after a few hours of running it was sound also . Mine now is decated and white smokes alot if its not using oil or water i wouldn't worry too much
  • markyp2000
25 Mar 2015 18:02 #141315 by markyp2000
Replied by markyp2000 on topic Constant white smoke
Mine smoked on start up an as you drive it hard i did a full rebuild ie piston rings. valve stems and valve stem seals big end bearings. the problem on mine was the holes on the piston skirt behind the oil scraper ring were blocked due to lack of good servicing
  • helijohn
25 Mar 2015 19:14 #141328 by helijohn
Replied by helijohn on topic Constant white smoke
markyp2000 wrote: the problem on mine was the holes on the piston skirt behind the oil scraper ring were blocked due to lack of good servicing
Is that not fixable in situ so to speak. :unsure:
  • mickt
25 Mar 2015 20:15 #141339 by mickt
Replied by mickt on topic Constant white smoke
Could be a lot of water had got in the exhaust with it standing and you are just boiling it off. Give it a few weeks of hard running before digging deeper I would suggest.
  • tommyguns
26 Mar 2015 00:21 #141361 by tommyguns
Replied by tommyguns on topic Constant white smoke
what mickt said, I put a straight through on and it was smoking more, panicked thinking oh bugger HG gone, but its just the water condensing in eggsause and gone within few mins
