could it be head gasket
- nickcroc
04 Jan 2015 16:41 #134109
by nickcroc
could it be head gasket was created by nickcroc
hi folks bought a jimny last august Cpl weeks ago thought id check water antifreeze and found a small amount of the white gunk in header tank expiation tank not a lot flushed system and added antifreeze but small amounts keep coming back around water level on ruber tube and on radiator cap oil clean as a whistle no gunk on filler or dip stick no loss of oil no white smoke runs great starts first time any ideas
- Olucas91
04 Jan 2015 17:51 #134122
by Olucas91
Replied by Olucas91 on topic could it be head gasket
That's how mine started. Best thing to do is get it tested before it gets worse to make sure. I Know a few who have used K-seal in the radiator to cure it early on with no problems or after effects.
- troggy
04 Jan 2015 17:59 #134125
by troggy
Replied by troggy on topic could it be head gasket
I seem to be losing water but no idea where from. Starts and runs, no white smoke except on cold start, header tank level ok, did overheat and bust a rubber pipe ( busted thermostat) fixed that. getting bits of the rubber pipe coming to top of rad, fish them out and give it a partial flush. Then resealed the blanking plate at back of engine in case it was that. not overheating but still seems to be losing water? no drips under car, help!
- troggy
04 Jan 2015 18:04 #134127
by troggy
Nickcroc, are you losing any water? I'm not getting any gunk and oil is clear, is it a similar prob to yours?
- Olucas91
04 Jan 2015 18:05 #134128
by Olucas91
Try K-Seal and see what happens if you don't want to strip the engine. Only about £12 from auto factors. Mines too far gone and head cant be skimmed no more so putting in a G16.
- nickcroc
04 Jan 2015 18:18 #134129
by nickcroc
Replied by nickcroc on topic could it be head gasket
not loosing any water or oil
Time to create page: 0.300 seconds
