trouble starting the jimny
  • logun94
01 Dec 2014 00:33 #131150 by logun94
trouble starting the jimny was created by logun94
hi guys recently my jimmy has had some issues with starting ,it turns over for about 5 seconds and then sounds like the battery is completely drained and it doesn't have enough power to turn over anymore ,initially i thought it could be a dying battery so i purchased a bosch battery from euro car parts and hooked it up after giving it a full charge ,unfortunately no change so iv eliminated the possibility of it being a dodgy battery , the thing is the jeep will bump start no problem first time but will not start with jump leads just looking for ideas thanks in advance
01 Dec 2014 08:25 #131160 by kirkynut
Replied by kirkynut on topic trouble starting the jimny
Starter motor! Undoubtedly James on here can sort out a second hand one for you!
James, this chap needs a starter motor for the car in the picture!
The following user(s) said Thank You: logun94
  • oilypirate
01 Dec 2014 10:19 #131177 by oilypirate
Replied by oilypirate on topic trouble starting the jimny
kirkynut wrote: Starter motor! Undoubtedly James on here can sort out a second hand one for you!
+1 on that if it bump starts fine has to be the starter motor
  • logun94
01 Dec 2014 13:54 #131191 by logun94
Replied by logun94 on topic trouble starting the jimny
hi guys thats what i thought but what confuses me is if the jimmy had been started via bumping it ,after leaving it 5 minutes it will turn over with the key absolutely fine and where would i get a starter kirky , thanks
01 Dec 2014 16:25 #131206 by kirkynut
Send a PM to j999pre and he will likely have one for you to send by post. He is the forum's resident Jimny breaker!
  • Grego
01 Dec 2014 17:09 #131209 by Grego
Replied by Grego on topic trouble starting the jimny
Once the engine oil is warm it could turn over ok even with a knackered motor and battery, its the thick cold oil that adds resistance, altho starters can also give up instantly when their time is up
Time to create page: 0.862 seconds
