cb mounts
- suzukisam
- Dyl
www.thunderpole.co.uk/fixed-body-mounts/...-side-mount-kit.html
I've never actually taken the back panel off the rear door but I expect it's quite straightforward to do and bolt the mount to the rear door?
- jonesyba420
If using a short aerial for your cb I'd suggest a roof mount as they dont SWR in to well on the rear door, mine is on the verge of unnacceptable as i only use a short whip so it doesnt stick above the roof to much.
my VHF/UHF antenna is on the roof rack and i swap to a cheap stubby sprung whip when offroad as i dont need as much range.
Can take pics if you want.
jonesyba420 wrote: Made mine.....just a piece of ally bent 90degrees.think its attached using one of the rubber stops for the spare wheel with a small bolt through the door to stop it spinning.cant really remember was a long time ago.
Surely the rear door is a big enough ground plane for you to tune the swr.
Have you adjusted it's length to tune it in?
I had to cut an inch off mine to get the swr good. Now it's spot on.
- jonesyba420
- Lorry
The coax comes back under the bonet and into the car through the grommet the bonet release cable and as mine is a soft top there is a steel section above the seats the cb is stuck to the roof with magnets from pc hard drives (they are very strong) can all be removed in seconds.
Lorry
