Newbie Tyre Advice
30 Oct 2014 13:35 #127941 by minibbb
Replied by minibbb on topic Re:Newbie Tyre Advice
Busta wrote: If you want to fit 195/80 15 or 215/75 15s you will need to remove the front mud flaps and the slightly larger circumference will have a small but noticeable affect performance.
I didn't remove the mud flaps to fit my 215s
  • Reloaded
30 Oct 2014 15:17 #127943 by Reloaded
Replied by Reloaded on topic Re:Newbie Tyre Advice
I didn't have to either when I fitted 195/80/15 KL71s to my standard(ish) Jimny runaround - I did however have to remove them when I installed 32mm wheel spacers as well and a 2" lift.
30 Oct 2014 17:35 - 30 Oct 2014 17:37 #127950 by jackonlyjack
Replied by jackonlyjack on topic Re:Newbie Tyre Advice
ive fitted 195 80 15 MT you just have to give it a few more revs to get the performance
and play with tyre pressure till it feels right
i settled for 25psi on all 4 corners for road use ;)
and the speedo is bang on now
Last edit: 30 Oct 2014 17:37 by jackonlyjack.
30 Oct 2014 18:03 #127953 by Busta
Replied by Busta on topic Re:Newbie Tyre Advice
Ah ok! I had to remove the front mudflaps to fit 215s but it would seem this isn't always the case then!
  • jonesyba420
30 Oct 2014 18:09 #127954 by jonesyba420
Replied by jonesyba420 on topic Re:Newbie Tyre Advice
jackonlyjack wrote: ive fitted 195 80 15 MT you just have to give it a few more revs to get the performance
Agreed, I run 25psi all round aswell.
30 Oct 2014 18:42 #127957 by dirtydogz
Replied by dirtydogz on topic Re:Newbie Tyre Advice
I also run 25psi B)
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Time to create page: 2.470 seconds
