Brake caliper
  • mickt
15 Sep 2014 16:43 #124200 by mickt
Replied by mickt on topic Brake caliper
I went back on the Bigg Red website and although they do not supply the caliper they do do a seal overhaul kit. £27.90 mind, although it is for two calipers. The sliding pins are separate items but that selection area on line is being upgraded so I will give them a ring tomorrow.
  • mickt
15 Sep 2014 18:41 - 16 Sep 2014 10:10 #124218 by mickt
Martin, that's a good price for the caliper. If the one from j999pre falls through I will get in touch.
Last edit: 16 Sep 2014 10:10 by mickt. Reason: remove members name as requested
  • mickt
16 Sep 2014 10:33 #124259 by mickt
Phoned Bigg Red today and they could supply the seals for the sliding pins separate at £2.90 each but could not supply the pins.( The caliper overhaul kit has all the seals for 2 calipers and costs £27.90. Bit of a waste for me as the pistons are OK, it is just the sliding tubes that are the problem) But the chap was good enough to put me on to :- " www.brakeparts.co.uk " who actually do a kit which includes not only the seals and sliding pins for one caliper but two new bolts and a sachet of grease all for £11.76 posted! Result or what. Thought I would pass on the website in case anybody else needs bits for their brakes.
  • GuardianAngel
16 Sep 2014 10:48 #124260 by GuardianAngel
Replied by GuardianAngel on topic Brake caliper
mickt wrote: Phoned Bigg Red today and they could supply the seals for the sliding pins separate at £2.90 each but could not supply the pins.( The caliper overhaul kit has all the seals for 2 calipers and costs £27.90. Bit of a waste for me as the pistons are OK, it is just the sliding tubes that are the problem) But the chap was good enough to put me on to :- " www.brakeparts.co.uk " who actually do a kit which includes not only the seals and sliding pins for one caliper but two new bolts and a sachet of grease all for £11.76 posted! Result or what. Thought I would pass on the website in case anybody else needs bits for their brakes.
Thanks for that. Also here is a video on YouTube on how to refurbish a caliper using said kits.
  • mickt
16 Sep 2014 18:57 #124305 by mickt
Many thanks for video. It is always easy when everything is brand new and clean!
  • suzuki jimny fella
16 Sep 2014 19:39 #124315 by suzuki jimny fella
Replied by suzuki jimny fella on topic Brake caliper
handy vid
Time to create page: 0.646 seconds
