Liana engine
  • Nicks_Jim
11 Sep 2014 19:44 #123906 by Nicks_Jim
Replied by Nicks_Jim on topic Liana engine
j999pre wrote: Liana injectors in jimny manifold
Jimny exhaust manifold
Jimny sump
Jimny oil pick up pipe in sump
Jimny Crank pulley
New oil filter screw
Jimny rocker cover
Studs for water pump pulley and jimny pulley
Think that it is
do i need to swap over the engine sensors or do i leave the 16 liana ones on, also i'm looking at a auto liana, would the auto flywheel be ok or do i need the 13 flywheel. cheers Nick
11 Sep 2014 21:12 #123914 by j999pre
Replied by j999pre on topic Liana engine
Jimny flywheel and clutch. Also thermostat housing and pipes and front and back of head water outlets. Three studs on front of head are in the way and need removing. Don't forget the o ring on the oil pick up pipe. Liana sensors will be fine. Don't just liana throttle body even though It's wider as it won't idle right.
Grey pick up Jimny
The following user(s) said Thank You: Nicks_Jim
  • Nicks_Jim
12 Sep 2014 05:31 #123922 by Nicks_Jim
Thanks james, topman!!!
Time to create page: 0.523 seconds
