Liana engine
  • Nicks_Jim
01 Sep 2014 20:58 #123168 by Nicks_Jim
Liana engine was created by Nicks_Jim
Will this 16v 1.6 liana 07 engine fit my 1.3 16v Jimny and what mods do I need to do to make it run properly. Any help cheers
  • Back in Black
02 Sep 2014 08:13 #123185 by Back in Black
Replied by Back in Black on topic Liana engine
Sorry, I can't answer your question, but I am also interested in any replies that you get on compatibility of the 1.6 engines, which engine goes in which cars!
I've been doing quite a bit of research on this and have found the following very informative for the actual conversion:
www.auszookers.com/forum/viewtopic.php?f=17&t=30308
There has been a lot of posts on here about the conversion too.
02 Sep 2014 09:48 #123198 by kirkynut
Replied by kirkynut on topic Liana engine
From memory Supagaz is the man in the UK to ask. I'm sure that he has done this conversion.
  • Nicks_Jim
02 Sep 2014 18:58 #123237 by Nicks_Jim
Replied by Nicks_Jim on topic Liana engine
Thanks guys. i will see if i can catch up with supagaz
02 Sep 2014 19:02 #123239 by j999pre
Replied by j999pre on topic Liana engine
An 07 liana will be a m16 vvt so will only be compatible with 55 plate onwards vvt jimnys
You need an earlier non vvt if yours is a standard m13a 2000 to 2005
If it's a g13b sohc then you need a baleno or better still a 16v grand vitara engine
Hope that helps
Grey pick up Jimny
  • Nicks_Jim
02 Sep 2014 19:19 #123242 by Nicks_Jim
my a 54 plate so i will see if i can get hold of a older reg a non vvt. cheers james
Time to create page: 0.218 seconds
