Internally mounted winches
  • TomDK
24 Jun 2014 08:06 #118457 by TomDK
Replied by TomDK on topic Internally mounted winches
Just remember that extra bracing, engineering, extra cost and so on, quickly adds up being more expensive and heavier than putting a small winch in the rear.
  • Xtreme
24 Jun 2014 09:15 #118463 by Xtreme
Replied by Xtreme on topic Internally mounted winches
Yes at the end of the day if it ends up being heavier by a fair amount then running both winches I wont do it. Its just a project car and nice to do things a little different so cost etc is ok I just save up and do a bit at a time as I can afford it.
  • Bits4Vits
24 Jun 2014 12:01 - 24 Jun 2014 12:03 #118479 by Bits4Vits
Replied by Bits4Vits on topic Internally mounted winches
This is Rob from the ORA's Jimny Buggy winch -
The rear winch is actually mainly used to the front through a tube that ends up at a donut fairlead on the front -
And to winch backwards they take a loop off the drum and out of the fairlead and round a snatch block...
Very effective example on this YouTube video -
HTH
Dave
Last edit: 24 Jun 2014 12:03 by Bits4Vits.
24 Jun 2014 16:53 - 24 Jun 2014 16:56 #118500 by kirkynut
Replied by kirkynut on topic Internally mounted winches
More piccies of it in action as promised:
[IMG
[IMG
As you can see, you just grab a loop of rope from the top and run it through the fairlead to a snatch block and to the tree strop.
Rob uses Toyota axles though!
Last edit: 24 Jun 2014 16:56 by kirkynut.
  • TomDK
24 Jun 2014 18:14 #118516 by TomDK
Bits4Vits wrote: This is Rob from the ORA's Jimny Buggy winch -
HTH
Dave
The location of the winch is pretty clever. As I see it, there is one major design flaw. The winch is mainly for winching forward, but the winch is mounted feet-backwards. Meaning the only thing holding the winch is the 6 mounting bolts. Not good enough.
24 Jun 2014 18:34 #118518 by Busta
Replied by Busta on topic Internally mounted winches
Still stronger than feet down though, and a good compromise for forwards and backwards use?
Time to create page: 2.451 seconds
