winch mounting
  • oxford_bloke
23 May 2014 16:30 #116123 by oxford_bloke
Replied by oxford_bloke on topic winch mounting
im doing the same thing with mine you just have to be careful that the rope is going the right way round the drum and the gearbox is in the upright position!
  • Tasscorp
23 May 2014 17:35 #116126 by Tasscorp
Replied by Tasscorp on topic Re:winch mounting
It wil depend on the brand. Warn winches use to have a couple notches on the motor side. This were used in order to let the water drain. If the winch is mounted in upright position the notches were able to do the job but if you mount it upside down the water will be held inside with all the problems knwon as rust, electrical failure etc.
"Si no entiende lo que escribí, es por que lo hice desde mi iPhone"
Time to create page: 0.147 seconds
