changing rear diff
- Thank you received: 115
15 May 2014 08:11 - 15 May 2014 08:13 #115263
by maverick
Jalapeño, IISY?
Replied by maverick on topic changing rear diff
honest, its a real easy job, you'll be amazed at how clever and simple the axle is on a Jimny.
I struggled for ages the first time i did this with:
a) Getting the brake drum off
b) Getting the handbrake cable off the shoes
But
a) There are two little holes in the brake drum, so screw in some 'spare' 12mm bolts and the drum comes off
b) use a tie wrap around the end where it goes into plate and its simple.
HTH?
But
HTH?
Jalapeño, IISY?
Last edit: 15 May 2014 08:13 by maverick.
- Bits4Vits
15 May 2014 08:13 #115264
by Bits4Vits
Replied by Bits4Vits on topic changing rear diff
I'll let you know in a blog soon when I stick my ARB AirLocker in the back
It's not far from yours to mine if I get stuck? :silly:
15 May 2014 08:15 #115265
by maverick
To a man off your talents P.O.P :lol:
Jalapeño, IISY?
Bits4Vits wrote: I'll let you know in a blog soon when I stick my ARB AirLocker in the back
Jalapeño, IISY?
- jonesyba420
15 May 2014 09:31 #115271
by jonesyba420
Replied by jonesyba420 on topic changing rear diff
When we done my rear wheel bearings we left the brake shoes in and disconnected the hand brake from the Y joint under the car (obviously remove the clamps that hold the cables to the chassis etc).
If your only doing it to remove the diff you dont need to disconnect the handbrake cable like maverick said.
- Johnbrom
17 May 2014 18:18 - 17 May 2014 18:19 #115556
by Johnbrom
Replied by Johnbrom on topic changing rear diff
Thanks all for your info, its very much appreciated.
Just have to find a diff now. Any suggestions for a reliable source for this part
thanks
Ps Had a bit of a steering wheel wobble so went underside and tightened up a few bolts
but put a few turns on a tie road end and wobble seems to have gone, happy days and fingers crossed
thanks
Attachment not found
Last edit: 17 May 2014 18:19 by Johnbrom. Reason: double picture posted
- Johnbrom
22 May 2014 15:28 #116021
by Johnbrom
Just reading through the thread again, whats the likelihood of the flange nut being loose.
Would it be a matter of just unbolting the prop and see a large nut to tighten???
Would be great if that's all it was :laugh: :laugh: :laugh:
Time to create page: 2.051 seconds
