3" lift what's needed..?
- 2014Nathan
26 Feb 2014 20:27 #106252
by 2014Nathan
3" lift what's needed..? was created by 2014Nathan
Hello there! Apart from the obvious springs and shocks, what's need for a 3" lift..? Extended brake lines, correction bushes? What else? Any help couldn't find anything maybe I wasn't looking in the right places!
- idiotmobil
26 Feb 2014 20:34 #106255
by idiotmobil
Replied by idiotmobil on topic 3" lift what's needed..?
Strong arms to lift a jimny 3"lol
- jonesyba420
26 Feb 2014 20:48 #106261
by jonesyba420
Replied by jonesyba420 on topic 3" lift what's needed..?
Look at the ORA 4 inch lift kit,everything you need is in there I believe other than rear shock relocation brackets.
- TomDK
26 Feb 2014 21:02 #106264
by TomDK
Replied by TomDK on topic 3" lift what's needed..?
ORA does not recommend using rear relocation brackets with their lift kits, because the shocks may bottom out and get damaged.
Also, these brackets are not really necessary. If you have an issue with the panhard rod rubbing the shocks. The shocks can easily be spaced out with a couple of washers.
But in general when lifting 3" and more. The bumpstops, front and rear needs to be made longer. Otherwise you still may damage the shocks and springs.
- jonesyba420
26 Feb 2014 21:05 #106265
by jonesyba420
I thought it was the shocks hitting the springs.
My bad :blush:
My bad :blush:
- TomDK
26 Feb 2014 21:10 #106266
by TomDK
That is also an issue with the ORA +4" kit. Both my front shocks have dents and scratches from the springs. Which is why I need to figure out what to do, when I get some better, more expensive shocks installed (Bilstein 5165)
jonesyba420 wrote: I thought it was the shocks hitting the springs.
My bad :blush:
