Best method. Paint from bare steel.
  • idiotmobil
28 Jan 2014 21:15 #102440 by idiotmobil
Replied by idiotmobil on topic Best method. Paint from bare steel.
I use a etch primer then a 2 pack gloss black on a lot of stuff and if needed throw in a high build primmer if I need a really good finish that's on new stuff or no rusty surface, for bits that are going a bit rusty I clean it up as mush as poss then hit with a rust converter then same as above but im not professional painter but I know the basics and can paint stuff properly if needed
  • Keefe
28 Jan 2014 21:18 #102443 by Keefe
Replied by Keefe on topic Best method. Paint from bare steel.
Thanks for all the input.
The items are rock sliders so not too worried about a first class finish, just want it nice and smooth.
I have a couple of cans of Rustolium satin black but it does dry with a gloss finish, hence the satin black spray to 'deaden' it a little..
Just off to 'Google' Por-15.
  • idiotmobil
28 Jan 2014 21:21 #102447 by idiotmobil
be carefull with the weather at the moment as the moisture in the air will turn gloss flat (blooming)
  • GuardianAngel
28 Jan 2014 21:41 #102454 by GuardianAngel
Replied by GuardianAngel on topic Best method. Paint from bare steel.
Keefe wrote: Thanks for all the input.
Check out Youtube for POR-15. Lots of good videos showing the prep and final finish.
  • JerseyJimny
28 Jan 2014 21:42 #102455 by JerseyJimny
Replied by JerseyJimny on topic Best method. Paint from bare steel.
Ever thought of this line-x stuff?
Would be brilliant for rocksliders!
  • Keefe
28 Jan 2014 22:03 #102467 by Keefe
JerseyJimny wrote: Ever thought of this line-x stuff?
There's a thought.................. :)
