Rear shock locators?
- Docmartin4x4
12 Jan 2014 17:32 #100238
by Docmartin4x4
Rear shock locators? was created by Docmartin4x4
Does anyone think that the rear shock locators hang too low?
I been 'hung up' a couple of times now on these as they hang down below the axle casing, Has anyone modified them so they are at least level with the casing or would it compromise articulation?
Mart
Mart
12 Jan 2014 18:43 #100250
by robs5230
standard jimny - for now
Replied by robs5230 on topic Rear shock locators?
they hang low alright. i have a lifted jimny and managed to take one clean off the axle saturday. i thinkjimnybits do a skid protector but this in itself hangs even lower.
- JuanGuillie
12 Jan 2014 18:49 #100254
by JuanGuillie
Replied by JuanGuillie on topic Rear shock locators?
Can you take some pictures how they are mounted?
Normally they are not lower then te original fixation from the damper!
You also could put rear shock skid plates.
12 Jan 2014 18:54 #100255
by robs5230
i think docmartin4x4 is saying they maybe they should have been positioned somewhere else. they are very low even on a raised vehicle . they are also very vulnerable ( as mine was ). the skid will protect them but in turn will be lower still.
- steffan
12 Jan 2014 19:00 #100257
by steffan
Replied by steffan on topic Rear shock locators?
Has anybody cut them off and welded them top side of the axle casing
12 Jan 2014 19:21 - 12 Jan 2014 19:23 #100263
by robs5230
this is something i'm going to have a look at tomorrow as mine is off the axle. i'll be taking some measurements to fab up a new bracket. i think the problem will be having to change the length of the shock absorber as it will be mounted way higher. maybe a standard ( not lifted ) heavy duty shock will be required.
any thoughts anyone ??????????????
steffan wrote: Has anybody cut them off and welded them top side of the axle casing
Last edit: 12 Jan 2014 19:23 by robs5230.
Time to create page: 0.461 seconds
