Sealing the airbox when fitting a snorkel.
05 Jan 2014 21:49 #99287 by kirkynut
What do you guys do to seal the airbox when fitting a snorkel?
The air filter has a rubber seal but surely you don't rely on that do y'all?
There's a hole in the bottom of the filter housing that must need sealing too.
I'm guessing you water lovers with snorkels seal these up or there's not much point in a snorkel!
The inlet air temperature sensor is in the airbox too, so you can't really do away with that.
  • ne-crock
05 Jan 2014 21:53 #99288 by ne-crock
Replied by ne-crock on topic Sealing the airbox when fitting a snorkel.
I just used silicon to fill the gaps
No temps will be seen really on the inlet side so I presume it will be fine?
Had it submerged with battery shorting out and snorkel remained dry, I haven't sealed the box itself I rely on that seal
05 Jan 2014 22:01 #99289 by kirkynut
I shall have another look at the air filter and how well it seals it's self then. Maybe I'm not giving it enough credit.
  • ne-crock
05 Jan 2014 22:11 #99292 by ne-crock
If you can get hold of a smoke machine it's a good way of testing for leaks by filling the snorkel,
Seems a good seal to me I've never had any problems but I,m sure a bead of silicon round wouldn't hurt?
  • Wiltec17
05 Jan 2014 22:28 #99295 by Wiltec17
Replied by Wiltec17 on topic Sealing the airbox when fitting a snorkel.
I borrowed some squeezy gasket from work to seal the breather and the snorkel itself, havnt had a problem with mine so far.
05 Jan 2014 22:30 #99296 by robs5230
sikaflex 291 around mine but the box still relies on the seal
standard jimny - for now
Time to create page: 2.755 seconds
