seating position
12 Nov 2013 16:33 #90614 by Lambert
seating position was created by Lambert
Hi. Is it possible to move the front seats back and up like you can with a defender using mud rails?
12 Nov 2013 17:45 #90620 by kirkynut
Replied by kirkynut on topic seating position
I've never heard of it done but understand the need. Jimnys aren't subject of such an aftermarket like Landrovers so it would be some fabrication needed I'm afraid!
  • helijohn
12 Nov 2013 19:05 - 12 Nov 2013 19:12 #90638 by helijohn
Replied by helijohn on topic seating position
I fabricated some brackets from 50x50x5mm tube. Cut into a parallelogram shape it means you can access the bolts easily. You can move the position of the top bolt as far back as you wish as long as you can reach the pedals. Watch height as you need clearance for your knees under the steering wheel. I also added another inch height for the rear brackets. This way you can keep and use the existing bolts lower-to-floor but use longer bolts of your own for the upper-to-seat.
Last edit: 12 Nov 2013 19:12 by helijohn.
12 Nov 2013 20:00 #90658 by Lambert
Replied by Lambert on topic seating position
Ok so it's a home brew if I want to do it. Think if I do I will get an engineer to look at my design first make sure it's not dangerous. Cheers for the input.
  • helijohn
13 Nov 2013 23:04 #91022 by helijohn
11/60 wrote: make sure it's not dangerous.
On Minis and Fords years ago they simply used a bar of steel. ;)
  • Tadpole
15 Nov 2013 11:07 - 15 Nov 2013 11:27 #91260 by Tadpole
Replied by Tadpole on topic seating position
helijohn wrote: I fabricated some brackets from 50x50x5mm tube. Cut into a parallelogram shape it means you can access the bolts easily. You can move the position of the top bolt as far back as you wish as long as you can reach the pedals. Watch height as you need clearance for your knees under the steering wheel. I also added another inch height for the rear brackets. This way you can keep and use the existing bolts lower-to-floor but use longer bolts of your own for the upper-to-seat.
How did you get on with the inside (tunnel) fitting John, use the same :unsure:
Having looked again at the pics I can see one is of the inner fitting .... :pinch:
Last edit: 15 Nov 2013 11:27 by Tadpole.
Time to create page: 0.227 seconds
