Manual Hub Recommendations...
  • JAGM
17 Oct 2013 13:47 #86652 by JAGM
Replied by JAGM on topic Manual Hub Recommendations...
This is probably a silly question - but here goes anyway. If the standard hubs that come on a Jimny can be manually locked by taking the cover off the hub and locking them manually, why not do that and select the 4WD through the transfer box as normal? Does this not negate the need to buy and install new manual hubs, or am I missing something here??
Thanks!
J.M.
  • Grizzly
17 Oct 2013 14:01 #86654 by Grizzly
Replied by Grizzly on topic Manual Hub Recommendations...
JAGM wrote: This is probably a silly question - but here goes anyway. If the standard hubs that come on a Jimny can be manually locked by taking the cover off the hub and locking them manually, why not do that and select the 4WD through the transfer box as normal? Does this not negate the need to buy and install new manual hubs, or am I missing something here??
Thanks!
J.M.
There's no such thing as a silly question, just a silly person asking it ;) :P :laugh: :laugh: Sorry, just kidding!
That's exactly what I was thinking myself this morning... I've not found anything in any of my research that would suggest this is likely to cause issues. If this is indeed correct then I'm not going to bother with the manual hubs, just keep the auto hubs locked and use the transfer box to change between 2 and 4WD.
  • supergaz
17 Oct 2013 14:03 #86655 by supergaz
Replied by supergaz on topic Manual Hub Recommendations...
Thanks!
J.M.
Its to save fuel by disconnecting the front halfshafts, diff and front prop drag.
  • Grizzly
17 Oct 2013 14:09 #86656 by Grizzly
That's nothing major though is it?
  • JAGM
17 Oct 2013 14:39 #86660 by JAGM
Yes - but - there is always a 'but'!!!! If one buys new manual hubs, fits them, and drives around with them locked (selecting 4WD when necessary from the Transfer Box), surely the end result is the same. i.e. the half-shafts diff and front prop will still be turned by the wheels????????!!!!!!!!
So - why not just retain the original hubs???? Some people on this forum have stated that they do not notice any increase in petrol consumption when everything is turning!!
J.M. (silly person)!!
  • Grizzly
17 Oct 2013 14:44 - 17 Oct 2013 14:47 #86661 by Grizzly
The plan wasn't to put new hubs on and keep them permanently locked... At the minute though I reckon I'll just keep the hubs as they are (locked) and just use the transfer box to select between 2 and 4WD B)
Last edit: 17 Oct 2013 14:47 by Grizzly.
Time to create page: 0.210 seconds
