Losing the filler cap
13 Jul 2013 20:19 #76988
Replied by mlines on topic Re:Losing the filler cap
2003 no dangly bit
2005 dangly bit
Sent from my HP Slate 7 using Tapatalk HD
2005 dangly bit
14 Jul 2013 06:59 #77002
I've seen some with the one end wrapped around the actual filler nozzle so I'm thinking long cable tie! It's too hot out there to play at the moment.
Replied by helijohn on topic Re:Losing the filler cap
1998 soon dangly bit. :laugh: :laugh:mlines wrote: 2003 no dangly bit
2005 dangly bit
- Vacneb
14 Jul 2013 08:53 #77011
by Vacneb
Replied by Vacneb on topic Re:Losing the filler cap
I reckon a few inches of bog flush chain and a nut and bolt or to would do you fine.
14 Jul 2013 11:36 #77020
Replied by helijohn on topic Losing the filler cap
First I popped the top off the cap to see if it had any venting as I didn't want to mess with that. You can see the venting is done to the perimter of the top of the cap. The centre of the cap top is nicely reinforced and ideally strong enough for a screw, 2mm drill and screw.
I took a length of petrol resistant rubber off a sheet, shaped it to attach to the flap and the cap, loosely on the cap. Violá
- Vacneb
14 Jul 2013 11:38 #77023
by Vacneb
Replied by Vacneb on topic Losing the filler cap
Looks spot on! Easy fix and most probably a damn site more durable than the brittle plastic cord on mine!
- Tadpole
14 Jul 2013 13:49 #77037
by Tadpole
Replied by Tadpole on topic Losing the filler cap
Top job helijohn ........................
Time to create page: 0.739 seconds
