Tow-Trust towbar - any good?
- Johnniehec
- Thank you received: 56
02 Jul 2013 20:01 #75811
by Johnniehec
Replied by Johnniehec on topic Tow-Trust towbar - any good?
I've been trialling my Jimny for a couple of years now and I don't think the tow bar has ever grounded, it's so close to the axle. Not sure what make it is but same style as the tow trust.
02 Jul 2013 20:09 #75814
by Halford
Replied by Halford on topic Tow-Trust towbar - any good?
yes that's my next buy - some axle armour
and trailing arm protectors
- Sandspider
02 Jul 2013 21:15 #75830
by Sandspider
Replied by Sandspider on topic Tow-Trust towbar - any good?
Thanks all, some food for thought there.
What do people think of the original factory fit Suzuki towbars? Possibly been offered one on here!
07 Jul 2013 09:53 - 07 Jul 2013 09:56 #76319
by Busta
Replied by Busta on topic Tow-Trust towbar - any good?
I recently bought and fitted a Tow-trust towbar.
It is easy to fit and you definitely DO NOT have to remove the bumper! That alone was worth the extra £20 over some of the others on ebay. It came with instructions specific to the Jimny which were straighforward.
It does sit below the bumper so will affect your departure angle if you do serious offroading. At the same time, it's a chunky bit of steel so it's not going to get hurt if you do bash it on things occasionally. I'm normally towing a trailer when I'm offroad, so this hasn't affected my vehicle ability.
It came with 7 pin electrics that mount on a bracket beside the hitch, but I've since mounted the socket in the number plate recess to make removing the hitch easier (just 2 m10 bolts and it's off, no cables).
Here's a pic!
Here's a pic!
Last edit: 07 Jul 2013 09:56 by Busta.
The following user(s) said Thank You: Sandspider
- Sandspider
07 Jul 2013 20:27 #76361
by Sandspider
Thanks Busta.
- ZookFastback
07 Jul 2013 23:25 #76397
by ZookFastback
Replied by ZookFastback on topic Tow-Trust towbar - any good?
We tend to use the Hayman Reese Tow Hitch in Australia. The hitch is easily removed from the towbar with the removal of the pin, which can be locked to prevent theft. Assists with rear clearance. They are available in 40mm x 40mm or 50mm x 50mm. The hitch can be replaced with a winch-mount cradle and can be used in front and rear applications so that is very handy, especially as it means you only need to carry the winch when going "Bush".
The white part in the photo is the Hitch, mine has the locking pin which is strong enough to use as a tow-point for recovery. This assembly is rated at 2200kgs, far in excess of the Jimny ability to tow.
Time to create page: 0.204 seconds
