Rear hazard/fog lights
  • helijohn
31 Oct 2013 17:30 #88754 by helijohn
Replied by helijohn on topic Rear hazard/fog lights
gilburton wrote: Have you thought about how much extra light you are now putting out ?
I've had lots of motors with two rear fog lights. It's a bit motorbike looking when there is only one even if on the offside.
  • jerry
31 Oct 2013 18:13 #88762 by jerry
Replied by jerry on topic Rear hazard/fog lights
Most makers fit one fog light because having two often confuses traffic behind you into thinking your braking :dry: , I'll be keeping just the one ..... ;)
  • helijohn
31 Oct 2013 18:41 #88771 by helijohn
jerry wrote: Most makers fit one fog light because having two often confuses traffic behind you into thinking your braking :dry: , I'll be keeping just the one ..... ;)
I think they do it for economy!! Can't see how two lights being on permanently would be like braking and the extra light could be a lifesaver in thick fog, brakes or otherwise.
31 Oct 2013 18:56 #88777 by Busta
Replied by Busta on topic Rear hazard/fog lights
The lights are in a similar position to brake lights and the same brightness so easily confused. When you see 2 bright red lights your first instinct is that the car is braking. They can also make it harder to recognise the brake lights, as mentioned earlier.
Often the position of the fog light on one side is mocked by the reversing light on the other.
I genuinely think fog lights (and peoples failure to use them correctly) causes more problems than they prevent. I probably use mine twice a year, and switch them off as soon as a car approaching from behind knows I'm there. Why some people drive around with them on in perfect visibility or heavy rain is a mystery to me.
  • Dirtbird
25 Jan 2019 15:54 #201683 by Dirtbird
Replied by Dirtbird on topic Rear hazard/fog lights
Looking for more advice on this topic . Need a fog light reverse light and a work light that works with the reverse light .
25 Jan 2019 16:12 #201685 by Lambert
Replied by Lambert on topic Rear hazard/fog lights
If you are just after generic ones try a company called "bolt on bits" They're a bit land rover but have a useful selection of lights.
Time to create page: 0.447 seconds
