jimny tracking with bigger tyres. where?
  • jimnybob
13 May 2013 19:17 #70635 by jimnybob
Replied by jimnybob on topic jimny tracking with bigger tyres. where?
Thanks for all the replies guys :) took it to a local garage and they did it for 30 quid. Much better then it was, in that I can now just about do 35 without coming off the road :p got really bad death wobble! Not sure why though :(
  • markyp2000
13 May 2013 19:31 #70639 by markyp2000
Replied by markyp2000 on topic jimny tracking with bigger tyres. where?
I had wheel wobble but no play in king pins when i went to replace the half shaft seal i found the lower bearing was shot
  • vitara_mad
14 May 2013 10:19 #70668 by vitara_mad
Replied by vitara_mad on topic jimny tracking with bigger tyres. where?
get the wheels balanced if you not already had them done
  • jimnybob
14 May 2013 18:09 #70691 by jimnybob
markyp2000 wrote: I had wheel wobble but no play in king pins when i went to replace the half shaft seal i found the lower bearing was shot
where would I find the lower bearing?
  • jimnybob
14 May 2013 18:12 #70692 by jimnybob
vitara_mad wrote: get the wheels balanced if you not already had them done
who can I get to balance them? The place I took it to for tracking said 31" tyres won't fit in most tyre balancers. Should I take them to a lorry depot? Cheers
  • Dave cc
14 May 2013 18:21 #70693 by Dave cc
Replied by Dave cc on topic jimny tracking with bigger tyres. where?
markyp2000 wrote: There fobbing you off cos the tracking is a pain in the butt due to having 4 adjustments i did mine the other week took me a good hour as it was so far out i kept having to take the bars off to adjust each joint on its own
4 wheel alinement is so the stearing wheel is set straight
you can get front and rear wheel tracking done seperate
How do you track the back wheels on a jimny then ?
Time to create page: 0.339 seconds
