jimny tracking with bigger tyres. where?
  • jimnybob
12 May 2013 21:49 #70581 by jimnybob
I replaced my track rod ends last week and need my tracking doing now. Took it to kick fit, national tyres and formula tyres and non of them would do it, apparently the wheel size makes it impossible? Where does everyone get theirs done? I feel they were talking bullsh1t or is this true? I'm running 31" tyres with 30mm spacers. Thanks in advance :)
  • supergaz
12 May 2013 22:34 #70584 by supergaz
Replied by supergaz on topic jimny tracking with bigger tyres. where?
Best just to fit smaller tyres just to get the tracking done, they are also talking bullsh1t, this is coming from a GARAGE EQUIPMENT ENGINEER!.
  • jimnybob
13 May 2013 07:13 #70591 by jimnybob
Replied by jimnybob on topic jimny tracking with bigger tyres. where?
I'm thinking of taking it to a private garage and getting it done the old way with gauges. They were also trying to tell me that I needed 4 wheel alinement and all my castor angles changing. Smaller tyres wouldn't be a bad idea if I had a spare set. Thanks for your reply
  • markyp2000
13 May 2013 09:56 #70604 by markyp2000
Replied by markyp2000 on topic jimny tracking with bigger tyres. where?
There fobbing you off cos the tracking is a pain in the butt due to having 4 adjustments i did mine the other week took me a good hour as it was so far out i kept having to take the bars off to adjust each joint on its own
4 wheel alinement is so the stearing wheel is set straight
you can get front and rear wheel tracking done seperate
  • supergaz
13 May 2013 16:15 #70618 by supergaz
I'd love to know how they will adjust your castor angles!
I've never seen a mechanic yet that knows how to correctly do wheel alignment. Or even lift a car on a 2 post lift correctly/safely
I'm not digging at you Mark! I'd bring my Jimny to you if you were local!
  • reaper
13 May 2013 16:43 #70623 by reaper
Replied by reaper on topic jimny tracking with bigger tyres. where?
Bit to far for you but i take mine to a local tyre fitter , great set of lads and most of them off-road
Laser tracking no problems
www.wingerworthtyres.co.uk/
