HELP FUEL PIPES
- GuardianAngel
08 May 2013 08:16 #70247
by GuardianAngel
Replied by GuardianAngel on topic Re: HELP FUEL PIPES
Use copper pipe as well, not steel. Easier to work with and it will not rust. Just make sure it is rated for car brake lines (8000psi I think).
Also be careful when putting in bends. Dont use your hands as you will probably kink and fatigue the pipe. Find some tubing and use as a former to carefully work the bend into the pipe. That way you will get a nice even bend.
- JivingDaddy
08 May 2013 08:23 #70248
by JivingDaddy
Replied by JivingDaddy on topic Re: HELP FUEL PIPES
- markyp2000
08 May 2013 09:47 - 08 May 2013 09:49 #70256
by markyp2000
Replied by markyp2000 on topic Re: HELP FUEL PIPES
Id replace them even it you clean them and paint them and thay are still pitted it will fail plus the pipes arnt that thick any way and dont undertake the job if you dont no what your doing seeing as the brake are a major component
Yes i would fail them in that condition
Last edit: 08 May 2013 09:49 by markyp2000.
- Maddscottish
11 May 2013 20:10 #70505
by Maddscottish
Replied by Maddscottish on topic HELP FUEL PIPES
Thanks for the help guys much appreciated
Time to create page: 0.348 seconds
