Noise on transmission
  • colinjgraham
26 Apr 2013 16:31 #69529 by colinjgraham
Replied by colinjgraham on topic Noise on transmission
I have replaced gearbox and transfer box oils, no contamination. Local garage I use said gearbox bearings, £450 ish to strip and repair. Is that about right? Cheers
26 Apr 2013 16:49 #69530 by facade
Replied by facade on topic Noise on transmission
£450 to remove and replace the gearbox strip it down, replace worn bearings and refill with oil sounds reasonable.
They will also tell you that you need a new clutch when the gearbox is off (which is sensible) but will cost another £100.
As to whether this is the noise, I don't know, I've not driven it, but do you trust the garage?
  • Swifty
24 Jun 2013 18:55 #74944 by Swifty
Replied by Swifty on topic Noise on transmission
Hello, I have a similar noise on mine, did you get the work done and did it clear the noise?!?
24 Jun 2013 19:17 #74953 by j999pre
Replied by j999pre on topic Noise on transmission
Gearbox mount? Transfer box mount? Cat heat shield? Try the cheap stuff first and have a good poke around.
Grey pick up Jimny
  • Sponnie
24 Jun 2013 19:48 #74958 by Sponnie
Replied by Sponnie on topic Noise on transmission
I had similar noise and it was the input shaft bearing on the transfer box. Go under and have a wiggle. Excessive play and you will know there is a problem.
Sent from my GT-I9300 using Tapatalk 2
Time to create page: 2.470 seconds
