Noise on transmission
  • colinjgraham
22 Apr 2013 16:26 - 22 Apr 2013 17:23 #69247 by colinjgraham
Noise on transmission was created by colinjgraham
Hi, this is my first post so I may be covering old ground. My jimny has developed a grating noise from the gearbox or transfer box. It is more pronounced in lower gears and on the over run. It is almost gone in 5 th. It sounds as if the gears are running dry but it had been regularly serviced and there is no sign of oil leaks. Any help or advice is very welcome, cheers
Sorry, big thumbs and little phone, could this be moved to the technical forum please
Last edit: 22 Apr 2013 17:23 by colinjgraham. Reason: wrong forum
  • barnes
22 Apr 2013 17:42 #69249 by barnes
Replied by barnes on topic Noise on transmission
Hi there have you dropped the oil on diff and transfer box? Is there oil in there or contamination of oil ie water/swarf?
  • colinjgraham
23 Apr 2013 06:42 - 23 Apr 2013 06:43 #69302 by colinjgraham
Replied by colinjgraham on topic Noise on transmission
Hi, thanks for the reply, doing that today, hoping I don't find any swarf etc in there. I don't know the layout of the gearbox etc but it does run quietly in 5th so I hope that an oil change may help. I am away for a few days after lunch so I will post what I find when I get back, cheers, Colin
Last edit: 23 Apr 2013 06:43 by colinjgraham.
23 Apr 2013 21:08 #69337 by kirkynut
Replied by kirkynut on topic Noise on transmission
I've never heard one, so I'm not an expert on the subject but many people have complained of a similar noise and found the chain in the transfer box to have stretched.
Someone with some experience on it may be along soon to confirm my thoughts or blow them out of the water.
The following user(s) said Thank You: colinjgraham
23 Apr 2013 22:59 #69355 by facade
Replied by facade on topic Noise on transmission
Possible, the chain touches the casing on the overrun, but I would have thought unlikely, the chain needs to be really worn, they are good for 150,000 miles if kept lubricated and not abused.
Not my photo, credit to the original poster
23 Apr 2013 23:01 #69356 by facade
Other people have reported a grinding noise caused by the partial engagement of one of the front hubs, worth a look there.
Time to create page: 2.148 seconds
